EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
Finally bought me some ARP head studs and a layered headgasket from STM. From what I have read in my research, I can lube the bolts, hand tighten the head studs in the block, install the headgasket, put the head on, then torque the nuts from 0 to 90ft lbs in 4 steps. Since I am using an other than factory head gasket, does the torque stay the same or am I even correct on how I should install the head stud kit?
and where do you obtain the 'special tool' like the giant star socket for the arp nut
I MUST have this car running before winter hits since it is my only mode of transportation with 4 wheels and a heater. I have a long 1 hour drive to work every day and driving my motorcycle is not the way to go.
