dsmjunkie97
- 36
- 1
- May 22, 2008
Reading,
Pennsylvania
Hello, i have a 95 gsx with a fresh 6-bolt engine. My issue is it seems to be burning some oil at idle. I only have 20 miles on so far and the a/f ratio is perfect at idle. The engine has new internals, machine work, and new rings and valve seals. It does not smoke on initial start up but once it starts to idle it smoke pretty good constantly. Once i start driving it stops smoking until it idles for again for a minute. I have had 2 different turbos on it and same result. I do not have a pcv hooked up just the vent to the intake tube. Maybe my rings are not seated yet? Any helpful tips for diagnosis would be appreciated, thanks in advance.
