Artago
- 2,093
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
Very nice power curve, the car must be hella fun to drive.
You got any pics of the turbo setup?
Tom
You got any pics of the turbo setup?Tom
You got any pics of the turbo setup?I'm impressed you're not running out of fuel with the Denso 150lph.
.Very nice, I also agree ecmlink is close to a dynojet. I net 400-415whp and 430-440lbtq via ecmlink. But only made whats in my sig on a load bearing dyno. Damn heartbreakers. I may just hit the dynojet so I can be cool with my 16g power numbers,.
So.... then it's way way way off? I'm confused
Edit: Or are you saying it's close to a dynojet dyno but way off a load bearing dyno like mustang dyno?
Jayrolla,
Yeah, and thats why I use a dynojet
Looks like your making some serious power on E85, can't wait to convert over myself.
Gene, just curious why you shimmed the wastegate? Was it blowing open from the exhaust pressure alone? With the Blitz EBC there is a gain adjustment which affects how soon the WG begins to open relative to the target boost. The HKS probably has a similar feature.
THanks, Gene. I will be running the EVO3 intake manifold and it sounded like you were moving on to 272/272. It sounds like you were happy with the 264/272 but now want to shift your curve over and the 272 intake will achieve that, correct?
. I'm on HKS 264's and I bought the Kelford 272's which flow more like HKS 280's. It will probably shift the power to the right but as it stands I have way more torque than I need at the moment anyways.That's a beautiful curve.Just getting rid of the MAF is gonna bump the HP level significantly. Bout time you got on an actual dyno and confirmed your findings.
And here's a "Hell yeah!" to clocking the 16G. Hell yeah!
I disagree at least with the "significantly" part. 5-8 whp I can buy but I wouldn't call that "significant". I have had and used a GM MAFT setup, I went back to a 2G MAS. I didn't have any major problems with it, except for the tune was never consistent enough for my liking. Going back to a factory MAS, the car starts easier and seems to run a little better.
Now I am not saying on a car with a big ass turbo, there wouldn't be more of a gain from the GM MAFT, but I think on anything smaller than a 20g, it's not needed at all. Just my opinion which is biased on what I have observed.
They are talking about switching to speed density, not maft.
Maf-t is notorious for a "wandering tune" that you are describing.
You forgot to mention that 3 out of the 4 TB bolts on your car were lose, basically finger tight and that you refused to boost leak test your car when we were trying to diagnose your tune issues and you wouldnt listenwhen your O2 was obviously bad also.
These both "skew" your review of the GM MAFT, a piece that I have never really cared for anyway.
I picked up a huge gain going from a stock diameter intake to the FP 4" I think that I picked up psi and spool up not to mention top end.
Right now I have 4 different types of intake pipes I've tested. My testing has shown the ebay special 3" aluminum "injen" knockoff to be the highest flowing, I picked up 0.5 lb/min more airflow over my RRE 2.25" pipe, but I don't run it cause its a touch too long and it heatsoaks like crazy. To fit good it would have to be chopped in half, a good 2" straight section cut out, then rewelded 360*. I may do that and get it bead blasted cause it is a nice cast piece.
The other two flow far far worse (4" dia and 2.75" dia) and are from very big name companies, which I don't want to mention.
I already have on the drawing board a compressor inlet design that on the CFD simulation is beating out the 3" injen by a good margin, which already is the best I've ever physically tested and datalogged. Its very simple design, but since I'm going speed density I can optimize it for the bare minimum pressure loss. This is what I meant by "tricks"![]()
At some point, you have to do things yourself to get the most out of the turbo.
