1ghaaaaaw
- 313
- 1
- Dec 7, 2007
puyallup,
Washington
Im selling my 1992 eagle talon tsi awd , I have alot of time in this car and need to sell it for a truck. The car runs great no problems at the moment just passed emmisions and has a clean title. Body has 114000 miles on it and the motor im guessing is around 50,000 on a rebuild, except for the head that has around 2000 miles. here,s a list of what the car has..
BURGUNDY METALLIC
20% tint
beige/ grey interior with beige leather seats ( headliner is out and needs to be relined )
primered drift front bumper to acomidate fmic ( currently has stock front bummper on , but will come with the drift bumper)
true HID headlights in crystal housings with clear corners
stock 6bolt with 50,000 miles
ported head
port matched intake and exhaust mainifolds
arp head studs
4 layer metal head gasket
balance shaft eleminated
90 oil filter housing ported releif valve with external oil cooler
no a/c
no cruise control
emissions removed ( but will pass )
90 non cruise throttle cable
double pshroom air filter intake
14b turbo
sx performance fpr
fic 650,s
eprom ecu with stage 3 keydiver chip/ chipped for a/c clutch switch ( has studder box and no lift to shift.)
maft for gm 3inch
safc2 d1 edition
pocket logger/MMCd
AEMs TRU-BOOST b/c
30/30 boost gauge
oil press gauge
blinky af gauge
wallbro 255 fuel pump re-wired
2.5 turbo back exhaust
2.5 ic pipes into 32x12x3 fmic
TiAL bov
polished 2g tb elbow, polished and painted v/c and intake manifold
optima blue top
poly motor mounts
alarm with built in turbo timer
Fidanza aluminum flywheel
Fidanza 4 puck Kevlar clutch
Fidanza short throw shifter
skunk weighted shift knob
bearing shift cable ends
steel braided clutch lines
2g calipers front with sloted and drilled rotors front and rear
4 bolt rear
kyb gr-2
tein springs
ST Suspension front and rear sway bars
front and rear Megan Strut Bars
18x9 tork wheels on strata 225-40-18 tires
Most of these parts have less than 2000 miles on them. Im also putting in with this sale an extra hood and fenders, some mics parts, lambo door kit that i installed and didnt like, tubular header for 14b or 16g turbo, used generic 50trim turbo and tubular manifold with external wastegate, set of 2009 eclipse five stars with brand new low pro tires.
I you have any questions feel free to e-mail me, just give me a few days to get back to ya as i work odd hours. thanks
LOCAL PICK-UP ONLY.
BURGUNDY METALLIC
20% tint
ported head
arp head studs
no a/c
no cruise control
14b turbo
sx performance fpr
fic 650,s
maft for gm 3inch
safc2 d1 edition
pocket logger/MMCd
AEMs TRU-BOOST b/c
30/30 boost gauge
oil press gauge
blinky af gauge
TiAL bov
optima blue top
poly motor mounts
4 bolt rear
kyb gr-2
tein springs
LOCAL PICK-UP ONLY.
yeah i wanted to sell it fast before i changed my mind again.
