wiring harness plug cut what goes here??
eclipse_16g
272
23
Oct 8, 2008
Connecticut
this is a 96 gsx i bought the car as a shell put the motor in and there the plug right after the 4th injector plug is cut. there is two seperate both with three wires are red black and blue. here are some pictures
those are for the cam and crank sensors that 95/96's have i know this for sure i just swapped injectors on my car yesterday. sorry to bring you the bad news!
They are for the coil pack which is located under the fuel rail below where you are holding the wires.
they are for the cam and crank sensors not the coil pack
come on guys how can anyone say its for the coil pack do you not see the coil pack plug
unless you have/worked on a 95-96 you wouldent know what goes there because those are the only years that had those stupid sensors LOL. but the coil pack plug is in plain view
