jrpmp69
- 312
- Nov 8, 2003
Las Vegas,
Nevada
I have a 95 Eclipse GST and im having trouble figuring out why it wont start, this is what i have done to try to troubleshoot it so far:
1. I changed the coolant temp sensor cause the scanner said it was bad and the CEL turned off but still didnt start.
2. Changed the MAF cause the one that was on there had no honey combs, no luck.
3. I changed the fuel pump and it still didnt start.
4. Changed the power transistor and coil pack and checked for spark and it still didnt start.
6. I sprayed starting fluid into the motor and it started up but turned off when i stopped spraying, so i figured its not getting fuel so I changed the injectors and still no luck.
I cant seem to figure out what is wrong with it, there is no more CEL and when it does come on it says knock sensor malfunction cause the plug seems to disconnect itself sometimes. The only thing i have not changed is the injector resistor.
Any help is appreciated.
