GSXlaunch
- 392
- Sep 3, 2003
For over a month I have been having a problem with my 90 gsx going full lean. So bad it is not driveable. Ever since the Magnus Intake install it has been nothing but problems. When I first go to start it up it starts up fine...idles great, trims are good (on the rich side). Once it warms up, it goes full lean. I can hear the idle change as it goes lean. It starts to miss a little and I am afraid to keep it running for more then a few minutes at a time with out it cooling down. Again, once it is warming up, the o2 seems to cycle fine. Once it warms up, o2 trims are at 180-199% and o2 voltage is at .02 and stays there. Things I have checked and or replaced:
Fuel pump oring (checked)
Fuel pump strainer (changed)
Have a hot wire right to the pump
Voltage to the pump is 14
Fuel filter changed
changed to afpr (set at 38)
no leaks present at injector seals
checked for boost leaks via the carb spray method
drained tank and replaced with 93 octane
I dont know where to go next. This is driving me crazy. Does this sound like an o2 sensor that is failing? If so, I will buy a new one tomorrow. I am desperate people. Any and all help is greatly appreciated.
Fuel filter changed
