cincinnati4g
- 52
- Dec 13, 2008
Cincinnati,
Ohio
So i recently bought a gates racing kevlar timing belt/balance shaft belt and i cannot get the bolt/nut off the end of the crankshaft sprocket. i tried wedging a breaker bar on the bolt/nut and letting the starter turn over thus loosening the bolt. Well that didnt work. Also tried putting two longer bolts in the crank pulley bolt holes and holding them with a wrench in a wedging effect but it just bent the bolts. i read somewhere that you use a spanner wrench to hold the sprocket while you loosen the nut but i dont know what size spanner wrench or where to get one. Also if anyone else has any tips on how i can remove that bolt itd be really helpful.
Thanks
Thanks
