toofast82
- 3,037
- 20
- Feb 8, 2005
Tinley Park,
Illinois
AEM sensor work with the LC1?
Yeah, same Bosch LSU sensor!
You could still get the car dialed in pretty well on the AEM unit for now though.
I would make another pull when the car is fully warmed up also, but yes I would try adding some fuel in that area, as according to the AEM, you're getting up around 11.7:1
I agree. I forget Kris, does your AEM read correctly or no?
Not really
The WB logging issue is a bit perplexing, though. Without accurate WB data, it's really hard to gauge "good" timing values. If you're really running 11:1 on pump gas, for example, I would fully expect to pull a lot of timing.Tires got a lil loose, but moving back up in the world of timing.
