It's not recommended to remove them because they straighten the flow of air so that the sensor can accurately read the air coming into the sensor. I'd leave them in there. If their already out. Then your car will generally run leaner because of it. You should be able to tune around that with the SAFC though.
____________________________
Kletke - 16g @ 27psi on Meth
