Thread
ERL Performance Cast Exhaust Manifold for DSM (T3 / T4 / Mitsubishi Turbochargers)!!!
View Single Post
07-03-2009, 03:38 PM
Show Printable Version
Email this Post
permalink
maperformance
DSMtuners Supporting Vendor
MAPerformance
Car
92 Talon TSi AWD
From
: Plymouth, Minnesota
Registered
: Jan 2007
Tech Posts
1,354
Classifieds Rating
23
Reputation
ERL Performance Cast Exhaust Manifold for DSM (T3 / T4 / Mitsubishi Turbochargers) Now in stock!!
If you're looking for an exhaust manifold for your T3, T4, or Mitsubishi turbocharger that won't crack and is provisioned for an external wastegate off of the collector (like it should be!) then you are in the right place! In our opinion the range of flange options, quality of the casting, and price point make this the only logical choice for an exhaust manifold upgrade!
Split Collar Ring Option
Another feature unique to this manifold is the split collar ring (shown below). Select this option if you wish to have the ability to bolt on a 38mm flanged wastegate. You will simply position the manifold and select which of the three wastegate positioning ribs will work best for your setup. Cut the wastegate tube to length if necessary, bolt on the split collar ring, and you're ready to install your wastegate! Please note that a wastegate dump tube is not included.
PM ME FOR PRICING!!
____________________________
Chris Burd
AIM: burdatmap
Advertisement
To browse the forums without the advertisements above, Login/Register
maperformance
View Public Profile
Visit maperformance's homepage!
Find More Posts by maperformance
