direct port through the injectors?
amg_dragon
61
Jun 13, 2003
Bumblefart, Missouri
While researching a normal tap into the manifold direct port nitrous system I ran across this at directnitrous.com
Is this even possible with FIC 1050cc injectors? I don't have any gm injectors laying around to compare/measure against but this would be the easiest way by far to add nitrous!
Has anyone tried this method or is it just a gimmick setup?
I doubt there is enough room for that... Not to mention the whole spacing issue.
The adapter is supposed to be for "GM Bosch injectors", I'm sure something could be milled out for us if the two are incompatible. I just know we're cheapskates out of need and if there's a ready made part available... we'll exploit the crap out of it!
The spacing issue might only apply with a stock intake but I think there's enough room so long as the adapter isn't like 2" tall.
Another question would be if it would affect normal driving since it's moving the injector back an inch. I don't know how much it would affect the spray pattern.
Pretty much the same thing, I'm just wondering if it would work on a 4g63 and if so, how it would affect normal driving.
Yes, but NOS makes a kit for Hondas. Honda injectors have the same dimensions as our injectors(they use our stock injectors as upgrades all the time). So the Honda kit will work on a dsm. You still just need to deal with the fuel rail.
I would have to say that the noszle kit won't affect normal driving. I don't know about the one you posted though because they might be a different size.
