EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
Ok, I just got done installing a Walbro 255 fuel pump and some 560 injectors. I set my SAFC to -23% for the low throttle all the way across the board, then I set the high throttle to -21% for any RPM above 2800. For some reason around 6000 rpm's it starts knocking in second and third gear. I have tried to add more fuel but that just makes it start sputtering and still knock. The sputtering is not fuel cut!
I currently have these things installed :
6 Bolt JDM Engine
Cyclone Intake set to activate at 3800 RPM
Evo III 16g
SAFC2
M/T ECU
Push button Shift Box
Rewired Pump (Walbro 255)
AFPR
560 Injectors
NGK BPR6ES gapped at 28
Brand new OEM O2 sensor ( < 3000 miles on it )
Brand new knock sensor ( < 5000 miles on it )
Everything else is pretty much stock.
Before I added the fuel pump and the injectors, I was running 450's on the stock fuel pump @ 15 psi with no knock at all. Any ideas on what is going on? Any adjustments I should make?
Here is the best log I took while test driving for about an hour :
RoadSurge.com - CSV Conversion for ID : 20
Thanks for any help in advance!!! I really want to get this tuned right soon.
6 Bolt JDM Engine
Evo III 16g
SAFC2
M/T ECU
AFPR
560 Injectors
My data logger has a WBO2 reading on it but I think it gets an estimated reading from the O2. It shows numbers from 0 to 255 so I am guessing 14.7 would be 128. No idea on that though.
