boostx,
I don't understand what you mean by the "metal jacket" in step 4 and "outer metal sleeve" for the moustache brace.
Far as I can tell, you removed the "metal jacket" in step 3 for the subframe bushings, along with the inner sleeve?
And where is the "outer metal sleeve" for the moustache brace, I only see the poly bushing with the inner sleeve saved from the stock bushing?
Thanks!
EDIT -
Here's how I think it should go together, as far as subframe. The ring would go under all that, on the part of the bushing that protrudes. Is that correct?
Here's what I think you meant by "metal jacket", the bottom sleeve. Is that what you meant? If so, I don't get how it fits into this.
And
here's how I think the moustache one goes together. Again, is that correct?
Thanks boostx!
