mobythevan
- 200
- 4
- Jan 19, 2006
Calhan,
Colorado
That sucks with the ticket. I should have my 2.4 fired up tonight and see if I have any major issues.
I was just about to reply to this when I saw your post on our forums. Hook that airflow wire back up!I just installed link late yesterday and having lots of issues with global and deadtime settings. I cant get the car to lean out no madder how much global I take out.
, I felt so dumb, but I still had to let everyone know of my stupidity just incase someone see's my thread and has the same issue.
, it wasnt funny. Car was running all crappy and I didnt know what it was. Funny the car took two drives before it through a CEL.
., it wasnt funny. Car was running all crappy and I didnt know what it was. Funny the car took two drives before it through a CEL.
I got the fuel trims inline with a global of -32 and deadtime of 330. LTFT Lo 4.1%, LTFT Mid .08% and Hi was at 0%.
The idle clamp feature is amazing. I activated it and car has not stalled yet. Great job on that feature Tom.
the injector thing is weird, i have made 445hp on 750's, 518hp on 850's and 630hp on 1000's and all cars were on e85. with my car and my freinds car it was a 10% change from 93 to e85. here is a vid of our shop car making 600+hp on 1000's and e85.
Would you mind posting a shot of your maf settings? I tuned my 1250s and ended up at -55 global and 345 dead time. The trims were right in line. Nothing +or- %1. Thanks Eddie
jrohner said:Yeah, I'm at 414 on 750's, and my cousin is at 321 on 680s, both on E85. I think a lot of people must run way too rich on e85. They also worry too much about the injector duty cycle, which is far from accurate on the stock ECU-- I've heard of many people running IDC's showing 120-130% (everyones maximum seems to be different) with no issues, even on Evo8's & 9's. My friend's Laser shows 80-85% IDC and it's bone stock; my 1G Talon showed that it was about maxxing out the 680's that are now in my cousins 2g, and that car was stock except at 20psi on a 14B and E85.
I say If you can richen your tune, and the AFR's are still in line, then your injectors are nothing to worry about.
e85_4g63 said:Not to purposely get off topic, but Eddie those EVO 10 wheels look great on your 1gB. Back on topic, What fuel setup do you have in the car JayRolla? In your profile you only have on Wally 255 listed, nothing about a FPR or filter upgrade...
I had a thread over on dsmtalk in the manual transmission tech, " High Hp dsm tranny longevity" Check it out, it may be good information for you. I had timing around 24* but I saw minimal gains on dsmlink so I pulled it back to keep things safer. No need to raise that much heat when I wasnt gaining any power.
). With the e16g on my 2.3l, the 1st/2nd gear torque is down right brutal now. And I think I'm maxing my turbo up top due to the much better flowing stroker. Link is estimating 400hp and 328lbs torque, 43 lbs/min at 6600 rpms, 26psi falling to about 21 psi.I had timing around 24* but I saw minimal gains on dsmlink so I pulled it back to keep things safer. No need to raise that much heat when I wasnt gaining any power.
My KS kicks in at 200rpms after full boost hits. This helps a lot but there are still situations where it can get PK. Since I dont want that to happen on the dyno I will set the KS to kick in at 10k rpms so it never does just to make sure it dont hurt my run.
As with the high HP I know what it can do. At my altitude uncorrected I will be lucky to ever see over 380whp with cams. I could get away with some nitrous bring the power level up over 450whp uncorrected and still be pretty safe in the drivetrain area.
It seems to be when 500whp/tq is broken then trannys become an issue. People here making over 600whp have to replace there synchros every year to keep the tranny smooth. Not to mention I have a buddy with a twin disc setup that tends to tear through synchros in any tranny no madder how its installed.
Now with the nitrous I wont always have it on tap like I do with a turbo. So I will be my normal safe 16g all the time untill I hit the strip. To me this is a lot more safe than having a huge turbo making power all the time.
But I could be wrong and it all blows up. Im not going to run more than a 75shot at first. If I go stroker I still wont go too much bigger than what I have now. I even thought of a hx35 now instead to be more safe.
