- Thread starter
- #226
JayRolla
- 5,629
- 34
- Feb 23, 2006
Colorado Spring,
Colorado
Yea last night I did a hard shift to second and it got a little squirly. My fiance got all scared.
What machine work would you need to do if the gasket completely let go?re-surfacing the head most likely. By caught early I mean before I overheated.
. Overheating can = warped head.Composite fel-pro is identical to oem. I run them all the time on various setups and very high boost with 6bolt blocks (wider diameter head studs).
How are you prepping the head and block surfaces for the composite HG install? Just clean, dry, check flatness and thats it?
the injector thing is weird, i have made 445hp on 750's, 518hp on 850's and 630hp on 1000's and all cars were on e85. with my car and my freinds car it was a 10% change from 93 to e85. here is a vid of our shop car making 600+hp on 1000's and e85. yea i know its a honda but the 445hp and 518hp cars were dsm's.the teg was reving over 9k
YouTube - viktek gsr 606whp Dyno Run
