johnnyboy55
- 87
- Apr 3, 2002
Miami / Broward,
Florida
theres a lot around plus they get rid of them for aem gear and such.. ITs a good ecu and i think you can run upwards of 500 hp on it without a problem.. ITs essentially a standalone and if you compare your costs maybe 200 for ecu, 100 for tactrix cable, free ecuflash, 30 for evoscan, wire yourself or pay for harness a few hundreded (say 300) then you have a standalone for around 630 -- i wired mine myself about 90 or so wires but its well worth it.. although my car is not turbo stock so..
But I will be trying in on another BONE STOCK CAR just to check out a few things. The Evo8 ecu also has an output to trigger a secondary fuel pump relay for high loads that we don't use and can use for our advantage like boost control for fwd guys to go from low boost to high, or IC sprayers, or ice cream truck songs to come on under full load.
