Slippi84
- 4,454
- 20
- Jun 8, 2005
Cinnaminson,
New Jersey
Yeah while this turbo MIGHT not make gt42r peak hp but if it makes 750whp in a broader form then that would net just as fast times. I was gonna go stroker but I just picked up a IM that will alow me to go 2.0 and still spool downlow like a stroker and still rev high so I'm pretty souped about that. Aluminum rod 2.0 with some nice HD pistons
. The 1 and 4 cylinders don't ignite at the same time, so neither does the exhaust valves open at the same time. When the number 1 exhaust valves open, one pulse will leave. If the rpm are high enough, then the number 4 will open the exhaust valves and two pulses will be traveling down the tube. Only if you have one tube EXTREMELY long and the other EXTREMELY short will the pulses meet at the collector. Where there is not so drastic a difference in the length, then the pulses of each cylinder are still striking the turbine at separate times, just like with an open header design. It is a common mistconception that a TS setup makes a turbo spool faster because of causing the pulses to "fire evenly" across the turbine wheel or because of "pulse spacing", or because of "pulse pairing".
