ricktb
- 650
- 8
- May 20, 2007
Edmonton,
AB, Canada
1) oil all over the valve cover, even after new oilcap, and pcv valve. Could too much heat cause this? (been a problem ever since I installed a tubular manifold with wrap)
2) running rich at WOT, my gauge drops to 10.0 to 1 air/fuel, plus my exhaust tip is blackened. Would raising the boost lean out my stock tune (currently at 10psi) ? I have no safc or anything yet.
Thanks for any advice
-ricktb
-ricktb
It has since been replaced with a cover I got off another Talon with a fresh gasket set. The valve cover gasket kits comes with the valve cover gasket and the sparkplug gaskets. I used the Felpro kit and it fit excellently. I've been told to avoid their headgaskets though...
