Drifter27_04
- 335
- 1
- Feb 13, 2005
Winston Salem,
North Carolina
The car has been seating for a few month's I have finally gotten everything put back together fixing the issue I had. Tried the car out up the road a few times and the last time I was on my way back I went to pull out of the road I turned around on and going into pushing the clutch in second gear something gave and than my clutch is not disengaging.Would this be a good sign that one of the two (Clutch Master or Slave) could be bad. I have never had either of them to go out on me driving and as it happened after making a few trips up the road I am assuming that is the problem.......correct?
I have a 2600ACT, extended rod, welded clutch assembly, SS line from the master to the slave
. Seen it on ECM awhile back. Gorgeous.
