Ecu/coil pack question
talon187
1,043
Feb 11, 2003
torrington, Connecticut
Ok to make a long story short I noticed my ecu fust wasnt intacted. I put it out and took the pastic cover off and it looked like the link didnt wasnt damaged that the end on the metal tab broke. So i put in a new fuse and that one poped. Well i did some searching and i noticed right at the connector on the harness side for the coil pack plug that somehow the casing for one wire was totally gone. It was just about and inch of casing gone. Where it was gone was right were the metal barcket that the plug ones onto to stay out of the way was there. My question is if that were to touch metal would that cause the ecu fuse to pop? Or should i still do some searching?
Umm, wow. You ever heard of spell check man? I cant even understand what you're talking about. Re-type all that and i'll try and help you out, but until then I have no idea what you mean by most of that.
