Agency Power Blow off Valve
Maranello993
122
Apr 21, 2007
Niceville, Florida
I am seriously considering it because it is pretty inexpensive....
$200 is INexpensive for an item that does nothing to drastically improve the performance of your car? I was definitely raised in the wrong household.
Yea, 200 dollars has always been something I would consider "expensive". And as stated above, you can't go wrong with a Tial, which so happens to have a very proven 50mm BOV for 200 dollars.
I should neg-rep you all.
Did anyone consider his air metering needs?
I suppose I was the only one that thought of that and didn't recommend the Tial.
If your 1G valve is having a difficult time holding high boost levels, consider doing the Dodge Garage Mod. It will enable your valve to hold 25+psi with ease, and the cost of the mod is somewhere between FREE and $2.50....a hell of a sight better than $200.
So you claim. :mad::p
I only just recently switched from a DG modded 1g valve to a Forge unit. Had I realized my issues weren't with the BOV, I would have never moved on.
Just a thought. No big deal I'll just get a TiAL, but I just saw that no one had ever said anything about this one on this site and it would bolt right up to my UICP. Could anyone send me a link to the best place to get a TiAL 50mm?
i have had the greddy type s, blitz, and now the hks ssq.
to me it doesn't get any better then the ssq, looks good, you can dump out or recirculat it.
and now for an even better look :limited edetion hks ssq:
<a href="http://imageshack.us"><img src="http://img292.imageshack.us/img292/2237/blkbovwatermlb2.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
Welll, that's the main reason why I didn't want TiAL, the side vents make it impossible to recirc. I did see one on a supra that was partially recirc, but the only TiAL I've seen fully recirc is the big bulb/bong looking one. Anyway, I can't find it at any regular vendors, plus the recirc fitting doesn't look like it will line up right which is why I was looking in the first place. I liked the Agency Power one because it would fit my flange (1g) and I was just bringing attention to the product so that I could get an opinion, for all I knew, someone has used it and loved it. Obviously now I won't get it. (although I didn't really get an opinion on the Agency Power bov.)
The 1G will work.
DDG- Talon BOV mod for HIGH BOOST
Now you don't even have to search for it. You can also just plug that hole up with a thick home made gasket. I did on accident, it doesn't like to blow off all that well under 12-15psi though.
