JayRolla
- 5,629
- 34
- Feb 23, 2006
Colorado Spring,
Colorado
It is relatively easy to add boost or timing. The problem is: You can not do much, cause you'll need C-16, or Meth. What is relatively safe timing, if I want to run 25PSI on pump, with a mid frame turbo like 35R ???
Or get your self some e85. I dont even log knock anymore when I'm tuning. Just make sure timing doesnt go over 22* and then add boost. If I run a lean tune then I will start to look at knock but even at 12.1 afr, 30psi and 22* I still had zero knock.
), he let off after seeing the type of powerband the car had
I give this credit to stand alone engine management.
