New Clutch, 500 Mile Adjustment Coming Up
yeah i just put on a xtr stage 3 6 puck on my car and it sais that im to do that at 750 and 1500. i have no clue though. im got to the point where i can hit on it in every gear but i have to take my time shifting. does this mean m getting close to being fully broken in. because if i shift at 7 grand and punch it again it slips?:cry:
The hydraulic clutch system on DSMs (and, virtually all hydraulic clutches) self-adjust as they wear until you're down to not having enough friction thickness for they system to accommodate.
I found this on vfaq, it talks about clutch pedal adjustment at the bottom, hope it helps!2G AWD Clutch install
That is only for clutch engagement point - how far the pedal comes up before the clutch starts to grab. As Defiant said the hydraulic system automatically adjusts as the clutch wears. There is no manual adjusting needed.
Whenever the clutch is replaced you need to adjust (at least check) the release point. Its the point in pedal travel where the clutch starts to grab. Other than that, the clutch is a hydraulic working system, and no other periodic "adjustments" are needed.
