1992awdlaser
- 3,050
- 29
- Dec 5, 2004
Wallace,
North Carolina
That was done at the beginning of last year. I posted a log in the link forums and someone advised that I bump the sliders up to where they are. I'll go through and check the couplers when I get her out the next time. Thanks for all your help Pat!!!!
If you can't find anything obvious just up the 1600hz slider around 5%. Or you could leave it where it is. All it's going to do is slightly change the air/fuel ratio if you up it. That is already being compensated for with your fuel sliders though. So, if you change it you might need to change a couple of the fuel sliders slightly to get the air/fuel back where you want.
Glad to help.
I have this thing in my head that tells me I can't touch anything inside the motor. Timing belt, head studs, gasket, etc. Everything else on the car I've done. Turbo upgrade, porting exhaust manifold, O2 sensor housing, alternator, starter, fuel system, etc. I'm pretty handy with a wrench, but when it comes to something that may compromise the motor, my brain tells me that I can't. I know I could, but like I said, I'm a wus.
Keep in mind that I'm calling you during the install if I run into any problems.
