curious..
G3nX09
Aug 4, 2008
Valley stream, New York
Just wanted to know If the 4g63T from the 1st Gen. GSX is better or worse than the 4g63T from the Evo 5 i belive. and which one should i use for my 1gen AWD TAlon.. keep the 6 bolt or upgrade to the Evo....
NEW..
- Ty U Guyz.. But I Also Got Another ? Someone Told Me That There Likes A Extra Rod In The Motor It Self To Balance It Out.. And When It Comes To Boosting And Making Power It Tends To Snap.. Is That Tru And Would U Recomand Replacing The Bottom Of The 4g63t 1gen With The 2.3l Stroker...
it is a 6 bolt but whats bad about the Evo 5 motor?
Well that all depends on how much you are paying for the EVO 5 upgrade...If it's a free motor then yeah do it but if not you're better off building the 6-bolt motor up and use that.
it pretty much the same motor with...someone please correct me if im wrong..... a bigger turbo and fuelrail. theres nothing wrong with but why go through the trouble of a swap when you can make the one you already have an evo motor for about $500.
The Evo 5 uses a completely different motor. True its a 4g63 but a variant. It's rotated 180 degrees like the 420a motors are. Sorry, no dice. This engine isn't just a straight drop in replacement.
:dsm:
Well the evo 1-3 motors are the same fitment but they are 7 bolt motors. The only thing better about them is the evo3 16g turbo 510cc injectors and a better flowing intake manifold. Your better off with the 6-bolt 1ga motor and buying the evo parts.
:dsm:
QFT.
I've always enjoyed working on a 6bolt motor more then an Evo, just seems more at home.
It's called the balance shaft, and there's 4 billion threads about the pros and cons of removing it, just do a search. Good luck :thumb:
You can't use the motor from the Evo 5. You can use the ones from Evo 1-3 but you have to modify the mounts.
