50trimmed1g
- 262
- Dec 25, 2007
Orange County,
California
Please guys, help me out. I start school again tomorrow and I need my car to run. I installed a South Bend TZ series clutch last week. I also put in a flywheel resurfaced to .611 step, new Throw out bearing, New clutch fork and pivot ball. The car ran perfectly after the install for 2 or 3 days. Now I am having disengagement problems. It is really wierd though:
Here are some senarios to help you guys out>>>
1. starting the car up, I hold the clutch pedal down, Turn the key and the car starts. I keep holding the clutch down and I can put the car in any gear as long as I don't let go of the clutch pedal. If I let go of the clutch pedal and press it again, I cannot get it in gear unless I push really hard.
2. If I am in gear driving and I come to a light, I depress the clutch pedal and take the car out of gear. I have to hold the clutch pedal down in order to put it back in gear again. If I release the pedal and then press the clutch pedal again it is very hard to put it in gear.
3. This has gotton worse for some reason over the past few days. This is how it was a couple of days ago. I could approach a light in gear. stop while holding the clutch down, and let go of the clutch then press it in again and go into gear. As long as there wasn't more than a 3-5 second delay from the time I let the clutch out and pressed it back in.
If I am looking at the master cylinder rod by the firewall and turn the rod counter clockwise, the pedal will engage a little higher up, but it still feels like it isn't fully disengaging at the bottom of the pedal throw. WHen I force it in gear i can sometimes feel the car lurch forward just a little bit, but once it is in gear it stops moving forward. I know it is weird. I have already bled the system. I also doubt this is 2G Pedal Pump up.
Please help me out guys. I have had many unanwered questions here on tuners but this one must be answered please.
