LTUDSM
- 1,802
- 7
- Jun 27, 2005
Morrisville,
Pennsylvania
does anybody could help me to do a timing belt job,cause im kinda lost on how to tension the tensioner
i need some help ASAP!!!!
i need some help ASAP!!!!Follow along with the video below to see how to install our site as a web app on your home screen.
i need some help ASAP!!!!Are you reusing your tensioner, hence asking about how to tension it? If you're reusing it, you'll want to use a bench vise to compress it. Rotate the handle no more than 1/2 turn, let it sit for 20 seconds, repeat. Make sure you turn the handle s-l-o-w-l-y, otherwise you could damage the tensioner. I would volunteer, but I won't be home until next weekend and I'm not sure if I'd need any of the specialty tools or not (which are not currently with me). But if you're still looking for someone by next weekend, let me know.
Make sure you read over this a few times if you do plan on doing it yourself:
Timing Belt VFAQ (Timing Belt TSB - ENHANCED)
((( .The othe problem is that i need new crank and a new 6 bolt bare block. Does anybody know a good place where could i get one??? ### i looked in classifieds,dsmtrader,philadelphiadsm,craiglist,called jnz,turbotrix,extremepsi nobody has one
(((( im totally screwed....... Or could i just grab a N/T block,switch my wiseco pistons,eagle rods and new crank. would it work????ok guys Bad news,my 3rd cyl bearing melted due of lack lubing((( .The othe problem is that i need new crank and a new 6 bolt bare block. Does anybody know a good place where could i get one??? ### i looked in classifieds,dsmtrader,philadelphiadsm,craiglist,called jnz,turbotrix,extremepsi nobody has one
I was glad to see everything worked out as I was scrolling through your thread. Your best bet is to look for an uncut crank and rehone your block, but of course I'd bring it to a machinist to inspect it first.
