View Single Post
Old 08-06-2008, 06:43 PM   #12 (permalink)
daren_p
DSM Wiseman
daren_p's Avatar
Region: Central Canada
Classifieds Rating: (2)
Quote:
Originally Posted by Palashia99GSX View Post
On a side note or rather to help those of us who have not had to change light bulbs (lucky) or simply just don't know.
When choosing a kit... which bulb light should be chosen for single beam and hi/lo bi-xenon (if it matters)?
1ga / 1gb -
2ga / 2gb -
For a stock 2g headlight, you would want a 9006 bulb kit for the low beams & if you want to replace the high beams as well, they would be a 9005 kit. Personally, I basically never use the highbeams anymore, as they aren't needed. Also the bulbs take a split second to ignite, come on very bright white, then dim & then come back on gradually to full power. While doing so they change from a purple to blue to bright white (in my case), so not sure using them as high beams is the best idea.
Offline
[posts] [gallery]
Sponsored Links
