Quote:
Originally Posted by Artago
Can post some pictures showing the difference between 35W and 55W?
Same for 4300k, 5000k and 6000k?
Thanks,
Tom
I would imagine the 55w has more light output vs the 35w? If thats the case, I wouldn't recommend running a 55w on your typical street car. If you have a proper HID setup, with real HID projectors & correct cutoff then thats one thing but even though our factory headlight cutoff is pretty good (2gb's), its not 100% & I would think the 55w would be hard on oncoming drivers. The 35w kits are a HUGE improvement over our factory headlight (I run the 35w 5K kit from them). Just be sure to re-align your headlights & try & make the alignment on the "low side", to be nice to the other dirvers
As for colour temps, its hard to tell the actual light output but the white Talon on the left should be a 5K kit, while the right pic is 6K (I believe). There are additional photos on their main website (not the sale page listed above). My opinion would be go with the 5K, it is bright white with maybe a hint of blue. IMO it most resembles the actual light output of a "real" HID system. The 6K isn't too bad in some applications but that is the max I'd go. The higher colour temps look really rice, have less light output & are annoying to other drivers. But thats just my opinion
On a side note, I've had my SharpeHID kit for 3 months now, & I don't know if I can go back to regular halogens now
