Check to make sure that the IC pipe connecting to the TB isn't touching the T-stat housing.
I also have a 2G with a 6 bolt and I had a similar issue as you. The pipe which was designed for a 2G motor was up against the t-stat housing and not allowing it to go any further towards the driver's side of the car and close the space between it and the TB. I solved it by putting a small dent in the pipe where it was being held up and also using some generic gaskets which are thicker than the oem gasket. The gaskets I'm using are made by Mr. Gasket and have "1190" stamped into them. The hole in the gasket is just a bit bigger than the throat of the 60mm 1G TB and the bolt holes line up almost perfectly. Just a tiny amount of enlargement of bolt holes needed.
____________________________
Romeen
