Tanabe GF210 Dimensions
Jordanbutter
267
5
Jan 7, 2006
Colorado Spring, Colorado
I need the Dimensions, mainly the inner diameter. I need to know if they will fit on my Illuminas. I have the old ones with the spring height adjustment so I need a spring that has a 3in I.D. Anyone have some lying around they could measure for me? I can't find the Info anywhere. Thanks
- Jordan Butterfield :dsm:
Jordan - I am not sure the inner diameter of the GF-210's but I do know they fit over my AGX's fine when mine went on. I dont know how I could measure anything for you man (as mine are still on the car)...But I believe they would fit over the Illuminas. If no one on here would no the answers, give ExtremePSI a bell and they would most likely know as they sell both products man. Sorry I couldnt be of more help. All I can tell you for sure is that they fit over AGX's. Good Luck Buddy :thumb:
**Edit: When you say spring height adjusters are you talking about something like a slip over coilover style adjuster? If so, I will tell you the rears will fit and the fronts will not. I tried the exact same thing and they would not fit in the fronts.
Like these adjusters ??? Dont mind the crappy springs, just the actual adjusters here.
Yes they are like that. But I was looking at everything closer and the spring perches are wider than the perch on the strut it self, so if they wouldn't fit those theres no way it would fit the strut. Thanks though, maybe I'll give 'em a call.
