Turbo Talon DL
- 720
- 3
- Jan 29, 2005
Quincy,
Illinois
If somebody were to log 19.7 ms for injector pulsewidth and 90% IDC on stock fuel what would you think of this? I run 13psi on EVO III, cams, stock fuel, 9:1 compression. My O2s are always in the mid .80-.85 volts and maybe 1-3 counts of knock under WOT. The ECU runs in batch fire when under WOT but sequential otherwise? I know I need larger fuel injectors and pump with the performance I run. Thats an issue to be addre$$ed at another time.
All I know is that the last time I dusted off an older V-8 Stang (not really fair for him I know) my PW was 19.7 and my IDCs peaked at 90 something %. I could have bad injectors or a bad injector drive circuit but it hasnt acted up in such a long time and no DTCs. Im gonna get some old EVO III 510 cc injectors and use a hacked airflow sensor. Is that PW vs RPM chart generic or DSM specefic? My airflow is pegged at 1599 Hz if that helps. The stock boost gauge follows my autometer pretty closely at WOT.
I have a pump and injectors but no cash for a good FPR yet. Even at 9psi on this turbo my PW is about 15-16ms.
