View Single Post
Old 08-03-2008, 11:33 AM   #1 (permalink)
chris712vt
Proven Member
chris712vt's Avatar
Region: Mid Atlantic
Classifieds Rating: (1)
Reputation: chris712vt is more helpful than not
SFMU fuel pressure too high
Alright guys, I'm stumped on my "unadjustable" fuel pressure right now. Let me explain my setup, and what I've tried so far.
I think most of my mods are up to date in my profile if you need to reference that, but my fuel system consists of (95 fuel system) a Walbro 255 high-pressure, stock supply lines all the way to the rail, 450cc injectors, 97 fuel rail (eliminated stock fpr) with -4AN outlet, -6AN return line to SFMU, then SFMU's return reduces down to a 1/4" hose and back to the stock return line on the firewall.
I bought the SFMU from a 2GNT member who previously used with with 450s and 16psi, pretty much my setup, so I didn't change anything on it. When I first started the car it didn't idle well, but smoothed out after a minute and a little revving. I checked the fuel pressure and it was 42-45ish psi, with the vacuum line connected.
I tried loosening the fuel pressure screw on top, in fact so loose the screw came out, and the fuel pressure didn't change at all (but it did increase a little when I tightened it all the way down). I unplugged the vacuum line and it didn't change. I put in the little in-line vacuum reducer thing and that didn't make a difference. I tried keeping the bleed valve all the way closed, and fully open, neither made a difference. The fuel pressure just stayed at 40 some psi every time.
I decided, well 40+psi idling under vacuum or static pressure with 450s just means I'm running rich as hell, but it won't hurt the car. So I took it for a quick test drive down the street and back. It pulls hard and feels great once I hit some boost, but I need to figure out how to drop that fuel pressure down. Also, I've noticed when I first start it up after it's been off for a while it sounds like it's running on 3 cylinders, but once it warms up, or I rev it a bit, or I hit a little boost, it goes back to being normal and strong - I assume that's an effect of running so rich and possibly dousing the plugs with fuel on initial startup.
Anyway, here are a couple pictures and two videos (one shows startup and fuel pressure gauge, the other shows the test drive). Anyone have any advice or ideas as to why I can't get the fuel pressure below 40psi? I'd like it to be more like 20.
____________________________
Chris Manzione
2.2L Turbo 420a
Offline
Related 420A Auctions
Sponsored Links
