Hey Sam, do you guys still sell lower tie bars? I have seen some from another manufacturer and there is a problem with the exhaust pipe hitting or rubbing against the tie bar(The exhaust is an Apexi N1 exhaust). Do your tie bars compensate for that? And do you also make a front tie bar?
I think it would be pretty cool if you guys did a lower tie bar GB. Another thing I have been thinking of for awhile was a throttle body elbow. You do make one but, it won't fit with the 1G CAS. What I did was cut off the pipe and took a 90 degree bend and cut it to length and had it welded and it is a perfect fit. I wanted to know if you guys could make some of those for a GB. Thanks again for your help Sam.
____________________________
David Hopwood
