keltalon
Supporting VIP
- 3,476
- 966
- Jun 29, 2003
Luthersville Ga, Atlanta,
Georgia
Well guys as you know in a recent post entitle My new dyno number I put down some very nice hp and tq curves and this was done using a home made td05 20g turbo. I was so excited about those numbers I was convinced that a turbo upgrade would get me into the 400hp club for sure. So I purchased a Borg Warner s256 extended tip 49lbs/min turbo for this seemed, out of all my research to be the best choice for me. I installed it on the car and now I am having issues. First issue is the turbo spools very slow full boost about 5000 rpm. Second when it boosts it spike to 26 psi and drops very quickly to 20 psi according to boost gauge. Third the turbo is rated at 49lbs/min I am only seeing about 34 to 35lbs/min. here are some things that I have noticed. First gear pull boosts no more than 20psi. Second gear pull boost no more than 20 psi. Third gear pull boost gets to around 26 psi and quickly drops to 20 psi. Fourth gear pull boost gets to 26 psi and drops slowly to 20 psi. Another thing to note is that my karmen readings seems to flatten out about 2100hz. Here are some things I have tried already.
· Boost leak test and fixed them all. The system was pressure tested and holds 35psi very steady.
· Adjusted the wastgate rod as far as it will go. I can barely pull the actuator with pliers, after the adjustment, to get it back on the waste gate. So it has ton of tension on it. Infact when I pressure test the system and watch the waste gate is start to move about 40 psi.
· I even ran the car with the actuator disconnected and nothing changed.
· I even created a boost leak in the system, drove it down the road to see if the kHz reading would increase considering that the turbo now has to spin faster therefore sucking in more air from the mas. The kHz or karman reading did not increase which leads me to believe that the problem is that the turbo refuse to spin faster.
· I disconnected my down pipe to see if it made a difference nothing still the same.
· Next move is to rip the turbo off and send it back to bullseye power for inspection because something is definitely wrong. Before I do this please offer you suggestions as to what else can be done on my part. Thanks
My mod list
Hks 264 in 264 ex
EvoIII ex manifold
EvoIII 02 housing
Dsmlink v2
Aem uego wideband
Ross pistons/eagle rods
3 turbo back exhaust
Lightly ported head
Lightweight flywheel
Custom fmic short route piping
Stock intake manifold.
I will post a log when I figure out how to get it off my laptop!
My mod list
Hks 264 in 264 ex
EvoIII ex manifold
EvoIII 02 housing
Dsmlink v2
Aem uego wideband
Lightly ported head
stock rubber turbo intake pipe was the !@#$$% culprit. I am not going into a lot of detail but it would let the turbo bring in the air. now the turbo shines like it suppose to. so next i need to do some tuning. we cut to rubber section and put it closer to the turbo with a custom made pipe and the car seem 29lbs boost and drops to 25 by redline. so i just ordered the 4" pipe from FP. thanks again everybody who offered a suggestion
was urgent that i get the package.
