Timing issue
This should help you.
The crank sprocket mark is aligned when piston #1 is at TDC. If you have a dial indicator put something in the spark plug hole to act as a spacer (I used an extension) up to the indicator to tell when the piston up as far as possible. Some parts stores rent or lend indicators if you don't have other access to one.
Seth
