ShadeTreeDSM
- 269
- Sep 16, 2005
Fort Lauderdale,
Florida
was driving to a friends house yesterday and was cruising about 80mph and all of the sudden the engine started running like crap. pulled over to gas station and knew it had missing cylinders. popped hood and had car running. pulled each spark plug wire off while running. if i pulled cylinder 1 or 4 it would arc & then stall. pull 2 or 3 the car would stay running, no arcing. checked wiring and some wiring was loose, re wired it and started it, no spark. got someone to bring me a coil pack, changed it out, still no spark out of cylinders 2 & 3. ECU was just rebuilt 3 months ago. checked wiring at cam sensor and noticed the the seal on the cam sensor was leaking oil on to the cam sensor wiring, the wires were exposed and one they were touching eachother. so i rewired that also and still no spark !!!
only thing that wasnt changed out is the Cam Sensor. its the original 1990 sensor. flat greenish looking one. i have a 1993 cam sensor, black hall effect type. was thinking about using that to see if it would fix the problem.
so what could it be
only thing that wasnt changed out is the Cam Sensor. its the original 1990 sensor. flat greenish looking one. i have a 1993 cam sensor, black hall effect type. was thinking about using that to see if it would fix the problem. so what could it be
