Quote:
Originally Posted by InvaderGSX
Something happened recently and I cannot figure out what is going bad. First off I am datalogging with DSMlink and AEM WBO2. I have FIC 750cc injectors, Walbro 255 and MAFT with blow thru setup using 3" GM MAF. I am breaking in the engine, so I currently run directly off of the Tial 38mm wastegate so it is only about 12 psi running a Bullseye BorgWarner S256. Well running at WOT up to 5K I have no problems. Hitting AFR of 11.1 or so. Once I get to about 5500 and up it shoots to 17 AFR and my duty cycles go to 95% and obviously my car starts to sputter. I have a stroker motor with FP3 cams and I run an Aeromotive FPR. I also have braided stainless line with a high flow fuel filter from the rail to the tank. I have the MAFT zeroed out and just run all the fuel setting on dsmlink. I even put in some 110 octane race gas last night to see if it would make any difference and it didn't. I need to figure this out before I put the boost controller on. Any suggestions? Fuel pump I can toggle on and off with DSMlink so I verified that. The only issue with my pump is I think the sending unit might not be installed good after the fuel pump install because It shows a quarter of a tank when my gas light comes on. So now I put more gas in when it gets to the quarter tank mark. I get pretty bad gas mileage also.
More than likely, either the fuel pump install was botched and the o-ring cocked/rolled, or the pressure line to the fpr is unhooked or leaking. Either of these will cause the problems you are seeing. Basically, it is a low fuel pressure problem in boost and higher rpm.
