View Single Post
Old 06-27-2008, 07:59 PM   #620 (permalink)
chris712vt
Proven Member
chris712vt's Avatar
Region: Mid Atlantic
Classifieds Rating: (1)
Reputation: chris712vt is more helpful than not
Quote:
Originally Posted by bullettdsm View Post
If you are going to move your battery in an FWD, forward is the way to go. If you can't have it directly over your axles then putting your weight in front of them, is much better than putting it behind. I actually have plans on the NA that will put a fuel cell in that location (opposite side with a cage). That way, the fuel weight is no longer being "dragged (by being behind the drive axles) it is now helping to keep the weight of the car down on the axles for better traction.
MB
Sounds cool, but will you be adding anything in front of the driver's side front wheel to evenly disburse the added load up there? Otherwise all the weight of the fuel would be being applied to the passenger side wheel.
Offline
Sponsored Links
