I'm not sure I understand what information your looking for.
Are you trying to understand why you might be getting too much fuel on deceleration?
It may have nothing to do with the injectors, the ECU has to see the Idle Position Switch close before it will cut fuel off when coasting/decelerating. The IPS is the sensor on top of the throttle body over the pulley. It grounds the ECU signal when the throttle is closed and because the gaskets that surround it also electrically insulate it, it has a ground strap that runs from on of the mounting studs on the intake manifold across the top to a screw into the throttle body.
With a volt meter, you can measure the voltage at the IPS when the throttle is open and closed. When it's closed you should see 0v and it's open around battery voltage.
While you car won't see boost, pressure testing the intake will help you identify any vacuum leaks, bad vacuum lines, seals, or gaskets.
I'm not aware of the difference between the two versions of the 240cc injectors you have. On the 450cc injectors the main difference was the pintle cap that cause the later model to make two streams of fuel.
Are the pintle caps different on yours?
