Quote:
Originally Posted by DSM-ZERO
Alot of cars in my class all mount the battery in the same spot
If you are going to move your battery in an FWD, forward is the way to go. If you can't have it directly over your axles then putting your weight in front of them, is much better than putting it behind. I actually have plans on the NA that will put a fuel cell in that location (opposite side with a cage). That way, the fuel weight is no longer being "dragged (by being behind the drive axles) it is now helping to keep the weight of the car down on the axles for better traction.
MB
