1glaserturbo
- 591
- 3
- Feb 12, 2005
Creve Coeur,
Missouri
Ok, my biggest concern right now is just getting the car to turn over....which it won't because I've found a little problem.
1. On the manual starter harness (with an automatic starter) there are two plugs, on that connects to the wiring harness and one that connects to the transmission (if it's a 5 speed). My question is, is the harness for the starter different between the two (manual/automatic)? If so I'm in luck.
2. There is a connection on my transmission that I can clearly say I have no idea what plugs into it. 4 pin square connector, right next to the passenger side mount. I've got majority of the connectors plugged in except for this one.
3. Off topic but still relevant. In the center console there is a plug as well that connects to the shifter assembly, what harness do I need to plug that into?
4. Another off topic but relevant question. Behind the radio there is a rather wide plug (body side) that doesn't match up to the automatic wiring harness plug that is right next to the ecu. 3 plugs for the ecu, one for the starter relay ( i think), and another for ???
Thanks!
Thanks!
