Jeff822
- 636
- 2
- Jan 22, 2006
Easton,
Pennsylvania
Well I just changed the oil last week when I got the transfer case on, 4 1/2 QT's of Castrol 20w-50 and a Fram filter. I noticed the past few days the oil light has been flickering off and on but thought nothing of it because the wire on the oil sender kept falling off last week. Today I check the oil and it read nothing on the stick. It wasn't even tapping or knocking or anything. I put a QT in and it read just a tad on the bottom of the stick. I ended up putting 3 QT's of oil in it to get the correct reading and I just changed the oil and filter less then 200 miles ago. The only oil leak I can see actually dripping down is from the return line at the pan and it only drips once or twice then stops. Also I don't see any blue smoke coming from the exhaust, just black from running rich.
Umm, if your not burning, and you cant smell it coming from anywhere. Next guess would be that it drained though the oil filter or drain plug in the pan.
