View Single Post
Old 06-04-2008, 11:11 AM   #4 (permalink)
edgar420a
New Member/Lurker
edgar420a's Avatar
Region: SoCal
Classifieds Rating: (0)
Reputation: edgar420a is an unknown
Quote:
Originally Posted by syquest15 View Post
I would suggest a coolant flush and Thermostat replacement if your overheating. If you havent flushed your heater core you should do that too, flushing each seperately with water can get alot of crap out.
Humming around the head/belts. Check your bearing on the pullies, remove the belts and psin each one seeing if they make noise. You can also try lubricating the pulleys with the belts on, run for a few minutes let the grease work in and see if that gets rid of any bearing noise.
it could be something else too, just giving idears
while you do this and the belt's are off you can start the motor for a second or two, to make sure it's not your timing/ idler or tensioner making those noises. the car will be runnig on the batterie so don't run it too long.
Offline
