luisjo
- Apr 17, 2008
San Juan,
Puerto_Rico
Ok so the problem goes as this.... I changed my master cylinder, and let me tell you the clutch fluid was awfull almost like rotten so i chenged and then i find out that the clutch is slipping, so i change the slave cylinder and it still does the same thing.
The problem goes like this: I start my car in the morning and the clutch is working like it should grabbing down... so after the car warms up (doesent matter if running or just in the driveway) the clutch will start to slip even in first gear almost wont take off and the cluthc will grab at the end of the pedal, today i figured out that when i does that, i turned off the car and within 30 seconds i sprayed the master cylinder and the lines (without touching the transmision) and turned the car on and the problem was GONE, until it got hot again, i bought a clucth kit today but i know whitin me that is not the problem im really deppressed now because i cant figure the problem out and i need my car ASAP. PLEASEE some one help me what can it be? i remember that when i changed the pump it was raining (you know water expands as it gets hot so it can cause pressure on the system and wont let the clutch grab) but i bled the thing like 3 times, i think i could flush it but i dont know how,
