View Single Post
Old 05-28-2008, 12:25 PM   #3 (permalink)
1glaserturbo
Proven Member
1glaserturbo's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: 1glaserturbo is more helpful than not
Quote:
Originally Posted by HighPSI TSi Guy View Post
Depends on the setup but it will take 6-10 qts depending on the setup. When you fire it up, run it through all the gears while holding the car still, letting it sit in each position breifly, that way it makes sure fluid fills all the passages it's supposed to and gets properly circulated, then check the level before driving it.
Awesome, thank you!
Should I fill the converter up a little bit before I slide it onto the input shaft though?
Offline
Sponsored Links
