blizz99
- 1,010
- 11
- Sep 21, 2005
Zeeland,
Michigan
Hi. My name's RP and I'm in desperate need of automotive service. The problem I am having is that the car idles rough and if you give it gas then it will stall. It is a 1990 Mitsubishi Eclipse GSX w/ performance mods. I'm thinking it could be because of a boost leak making it run too rich or too lean or it could be a bad IAC. I'm not an expert so I don't know exactly what it is. Also, when I put power steering fluid in and try to bleed it, the power steering hose underneath the car will pop off. I'm located in Browns Mills, NJ 08015. Between the military and my wife being pregnant again I no longer have the time to work on the car anymore. I really need to get the car running right again. Thank you in advanced.
