Slippi84
- 4,454
- 20
- Jun 8, 2005
Cinnaminson,
New Jersey
I"m not gonna post the brand and if you know I would apreciate not syaing so as I want this to be more about the turbo's size and trim and .ar vs brand performance and what not. Below is the stats of the turbo I"m thinking about giving a shot. This will be a car that is street driven 97% of the time but I want to be able to put down 400whp on pump gas. By looking at the size specs of the turbo do you think that is a reasonable goal. If you know a turbo that has comparable stats chime in that woudl make it easier for me to make my descision.
!!!! I have a 420a not a 4g63 motor. I am fully built with high compression motor so spool should be a little faster than a basic 4g63 setup but I will limited in how much boost I can run!!!
Specifications:
Compressor: 50 trim 0.70 A/R
Compressor Inducer: 64.8 mm
Compressor Exducer: 91.4 mm
Compressor Inlet: 4 hose connection
Compressor Outlet: 2.5 hose connection
Turbine: 58 trim 0.63 A/R
Turbine Inducer: 73.4 mm
Turbine Exducer: 55.9 mm
Turbine Inlet: Standard T3 4 bolt flange
Turbine Outlet: 3" 4 bolt round flange
Center Housing: Oil cooled
Bearing System: Journal bearing
Wastegate: External
Specifications:
Wastegate: External
. WHat do you mean for my motor that's way to big. I have the same displacement as a 4g63 and yes I a built how else would I have high compression pistons?? Neither of the turbo's would do over 500hp without meth or race gas. I want this turbo to make 400whp reliably on pump gas and spool by 4500 by debat enow is to get the .48ar and sacrafice spool or do I hope my higher compression pistons will help a little with spool and get the .63ar and have a much better top end?
