Phalanx99
- 62
- 1
- Apr 22, 2006
Garden Grove,
California
1997 Mitsubishi Eclipse Spyder GS (2.4L turboed).
Mileage: 118k
Lots of mods:
97 Eclipse Spyder GS turbo list:
Tripple gauge pod + Oil Pressure, Oil Temp, Boost : $130
Gauge cluster : $26
Ebay HKS Blow Off Valve : $47
Evo VIII fuel pump : $55
550cc Injectors : $200
Tabular manifold with 38mm External Wastegate : $195
28X12X3 FMIC : $106
Intercooler pipes: $54
Injector resistor pack : $26
EGT gauge + Digital tachometer with shift light : $120
EPROM ECU : $230
Reducers and Couplers: $50
DSMlink + Socketted : $600
Turbo oil lines: $100
2g Knock Sensor: $40
1g Throttle Body: $50
2g Throttle Body Elbow: $26
3" Aluminum pipe with HKS flange: $20
- Infinity speakers all around. 2 way speakers front and 3 way speakers back: $200
- Megan racing front upper strut bar: $24
- JVC CD/MP3 player: $120
- RED interior lights: $40
- All stylist decals: $100
- Custom interior paint: $20
- Custom Red/Black leather seats: $100
- 2.5" Greddy cat back exhaust: $250
- Interior trims, hand brake cover, ball shape shift knob: $40
- Chrome dual projector headlights: $110
- Short shifter: $33
- BLUE silicon vacuum hose: $10
* Engine upgrade at 115k miles:
- 4g64 SOHC BLUE plug wires and Irridium spark plugs: $95
- Wiseco pistons 9.1:1 $460
- Eagle H-beam rods: $320
- ACT 2100lbs clutch with 6 puck disc: $300
- New 4g64 oil pump: $95
- New 4g64 water pump: $40
- New alternator: $150
- ACL race bearings: $90
- Balancer shaft eliminating kit: $25
- Multi layer metal head gasket and engine gaskets: $65
- FIAV and EGR valve block off plates: $20
- T3/T4 57trim turbo
- Custom made urethane motor mounts from stock motor mounts: $20
- 3" GM MAFS with 2g MAFT : $250
- New belts: timing belt, alternator belt, AC belt.
- New AC seals + refrigerant: $160
*** The car is not running now. It NEEDS a new motor. ***
Pictures: 4g64.com Gallery :: Phalanx's Spyder
Pick up only !
Asking price: $3000
Mileage: 118k
Lots of mods:
Gauge cluster : $26
28X12X3 FMIC : $106
EPROM ECU : $230
Pick up only !
Asking price: $3000
